Re: [VOOM/DISH/OTA] Voom newbie needs OTA HD help? | SatelliteGuys.US
  • Thread starter Thread starter Thomas Barthel
  • Start date Start date
  • Replies Replies 0
  • Views Views 2K
T
Thomas Barthel
Guest
Sounds like your unit is defective. I don't think it's the smart card
since you can still scan local channel with a deactivated one. On a
normal working receiver you would see a progress bar under option 4.
--- cchip2468 <cchip2468@yahoo.com> wrote:
> Hi. I am new to Voom, and was looking for a little info on the issue
> that I am having. I bought a Voom receiver hoping I can use it for
> OTA
> use. After hooking up the box I gained access to the "Install Wizard"
> and tried to scan for locals, but instead of the scanning the whole
> screen just blinks. This will keep on happening until I press back. I
> also tried to "Aim Antenna", but that doesn't do anything either.
> Secure Firmware:V16
> Current Software 02.4C
> HAL Version: 00.07.37
> Middleware Version: 01.45.02
> I tried removing the OTA module and inserting it again. I also tried
> a
> hard reboot, but no luck
> Does anyone have any suggestions?
Register to hide this ad
C
R
RE: [VOOM/DISH/OTA] Voom newbie needs OTA HD help?
