Read this. | SatelliteGuys.US
Read this.
  • Thread starter Thread starter Cascade
  • Start date Start date
  • Replies Replies 0
  • Views Views 2K
Cascade
Goose.
1,457
37.134004N 76.561779W
Just looking through the FAQ section I can see 12 out of the 19 threads in there which have been moved to the correct area.
If your post mysteriously disappears and you don't know why, it's probably been deleted or moved.
The FAQ section is not for questions on how to get your system working, it's a section to READ about how to get your system working.
The same goes for the review section, the amount of times we've moved threads from these subforums into the main forum is getting out of hand.
If you can't post to the correct section in the first place you won't get an answer because nobody is looking in the reviews section for questions or to answer you on how to get Telstar5.
If you're unsure about where to post, either ask a moderator (Myself, Iceberg or PSB) and we'll help you out, failing that you should post to "MPEG2 / Free To Air Discussion" because chances are we'll have to move it into there anyway.
Intelsat Americas 6 at 93.0°W What TP to use?
Korean FTA TV
