I was using this receiver as a dish mover. It could store satellites by letter and number. A few days ago it froze up with an "L" displayed where the letter for the satellite should be. It won't respond to any button presses at all. I don't have a remote for it, which might allow me to do a reset procedure. I can't find a manual for it, or a Drake 924 which is said to be equivalent. Radio Shack has part of the SR2010 manual online but nothing helpful.
So, I was wondering if anyone might know what the "L" means on an old receiver like this. I had just extended the motor wire and the pulse wire to a length of around 200-300 feet. Shortly after this is when the trouble started. I tried disconnecting everything and leaving it unplugged for a while but it's still locked up.
I wonder if possibly a parental lock happened to it, and the "L" means locked? Or maybe it has something to do with an east or west limit, but I thought that isn't something that would lock up the receiver and make it unresponsive. I haven't looked inside of it. I wouldn't really know what to look for except maybe a fuse. It has one in the back, which was not blown. The receiver still powers up in the same state with the fuse removed. Maybe it's for the motor circuit?
I don't have much hope that it will ever work again but I thought I might ask for suggestions, including what kind of box I should get to replace the old SR2010. It's heavy, and it's huge, but it looked cool with a lot of led's on it and a lighted analog meter and it was fun to try to figure out where a satellite would be, using the counter. I figured that 10 clicks on the counter was equal to one degree, so if it was on 91W I could figure that if I moved it 40 points to the west, it should be on
95W and it was nice to be able to store locations, but I think those days are probably over now, until I get a new dish mover.
