receiver got the wrong satellite | SatelliteGuys.US
xing68
7
Hi,
I have a dish receiver 322, I got channels from satellite 110, 118 and 119. But today after I did a check switch test, I lost sat 118, and instead I got sat 121 -which I did not subscribed. I still got strong signal from sat118, but the receiver just don't pick it.
How do I make my receiver to use the signal from 118 again?
Thanks!
Well without moving your dish your receiver can't change where it is getting signals from. What dish do you have?
Thanks guys, I moved the dish a little and that fixed the problem.
I think my dish can get signal from 110, 118, 119 and 121 since 118 119 and 121 are pretty close.
what kind of dish you have again?
if you have a 1000+ setup the sats should be 110/118.7/119/129.
almost nobody needs 121 anymore and no dishnet equipment is designed to pick up both 118 and 121 at the same time.
Difference between 250 + HD & Turbo HD?
722 Aborted Timers
