Receiver Question | SatelliteGuys.US
Receiver Question
sbsi
451
My Direct TV receiver is the standard basic receiver, the cheapest one.
Currently, the receiver is connected to tv channel 3 and I am getting a lot of fizzy motions on the picture.
Is there a way on the remote or receiver where I can change the receiver onto tv channel 4?
There should be a slide switch on the back of the receiver near the coax out connections that allow you to change it from channel 3 to channel 4.
Try reading the instruction manual that came with it seeing you can't read the model number.:)
SWM satellite setup help
Required equipment - suggestions?
