Is there a code for dish receivers to force a reset or just reset like direct has with 02468? ty for any replies and help
Is there a code for dish receivers to force a reset or just reset like direct has with 02468? ty for any replies and help![]()
I know this is a little off topic but (I don't want to but just wondering) can your reformat a 722? I know with Directv you could because old receiver I had when I had then kept having problems and they made me reformat it couple times before they realized the receiver was bad not the software. Does that fix issues with it or does it just delete your recordings?
IIRC, that functionality was eventually removed in favor of some fancy diagnostic tools that take a very long time to run.I know with Directv you could because old receiver I had when I had then kept having problems and they made me reformat it couple times before they realized the receiver was bad not the software.
Usually it just erases everything (your recordings as well as your programming preferences). It also purged the guide data.Does that fix issues with it or does it just delete your recordings?
Limited time offer
