Receivers with built-in destackers | SatelliteGuys.US
AeroGuy
4
Los Angeles
Has anyone compiled a list of D* receivers with destackers built-in? For example, I believe no tivo receiver does. Please post manufacturers and model numbers of receivers that you know of with built-in destackers.
None do. It would be a great idea if they made at least one SD and HD model available that did.
Never tried it personally but some of the Sony receivers (my B3 has the ability) can be set to WIDE mode which is supposed to make them work without a destacker.
Actually, none have de-stackers, but lowmazda is getting very warm. The best wide-band receivers are the Hughes HBH and HAH models. If you need a wide-band HD box use the RCA DTC-210.
-Robert
VE Advanced Digital Technologies Dealer
Channel 95 Mariners vs As tomorrow, will it be available to EI subs?
5 lnb dish size
