Hi Folks!
Last fall, I salvaged a decent 7.5' (2.3m) mesh dish with a Von Weise actuator, mounts and posts. And I'm hoping to add C-Band FTA to my TV this spring after the thaw.
Providing the actuator will function, I should have no troubles setting up the dish, and running cables and wires. I've had great results so far, with several KU band dishes & motors.
A friend gave me 2 LNBFs, and 3 VCII receivers (GI2600R, GI2650R, and 1 Zenith), as well as a GI2000PS power supply for the actuator. I know that VCII is kaput, but the boxes can still be used to move the dish.
My blind spot is with the C-Band components. I have no experience at bench testing any of this stuff, and know nothing about using the receivers to move the dish.
Can anyone tell me what kind of luck I will have with these parts? Can you link me to a "schematic" showing a common set-up configuration? I'm hoping to make-do with what I've got, or should I look around for something newer and better?
I am planning on buying a "V-Box" dish-mover to use with my FTA box, but I need to see what other expenses I must endure beforehand, as my budget is quite tight at the moment. I'm also saving up for a decent HD PVR for FTA.
I'm currently enjoying a motorized 3' dish with an Invacom QPH-031, hooked up to a CoolSat 7000, seeing around 25 KU birds from the eastern shores of Lake Superior. C-Band has been elusive to me, but is now within my grasp!
One other question: Will my Invacom QPH-031 work properly, mounted beside the C-Band LNBF, on the 7.5' prime focus dish? Have all my goodies on one basket? lol
I hope these pics are adequate.
Thanks for your time, any help is appreciated.
