Reception ERROR on 119?? | SatelliteGuys.US
SarKen
690
3
MA
I did a search and could not find an answer to my problem. I did a check switch the other day to update my program data. I got an error that said something about if there is bad weather please try again later. I select retest twice and still received this error. So I selected cancel.
Now in the check switch screen I get a "X" on 119 and a message that says "Reception ERROR" both with a red background. But if I exit I get all satellites and receive channels on 119 with a good signal strength. What could cause this and is there anything I can do to fix it?
I have restarted a few times and even unplugged the 622 from the power with not luck.
My setup is:
Dish 500 - 61.5
SuperDish - 110,119,121 (was for sd locals)
DPP44 switch
vip622
Thanks!!
Ken
diference between sw34 and sw33
Locals not mapped down
