Record Plus (Is bug fixed?) | SatelliteGuys.US
blockisle9
217
I asked this in the past, and just want to see if there is a fix yet or a software change.
Sorry for asking again
Record plus enabled, TV 2 set as preferred recording Channel.
*When I'm at TV 1 and set a timer, it records on TV 2, When I set a second timer for the same time it records to TV 2.
*When I'm at TV 2 and set a timer, it records on TV 2, When I set a second timer for the same time I get a timer conflict and I have to delete one.
Record plus enabled, TV 1 set as preferred recording Channel.
*When I'm at TV 2 and set a timer, it records on TV 1, When I set a second timer for the same time it records to TV 2.
*When I'm at TV 1 and set a timer, it records on TV 1, When I set a second timer for the same time I get a timer conflict and I have to delete one.
You've described how it still works on mine. The workaround is to set record plus to TV2 when at TV1 and vice-versa.
Ready to buy... but 2nd HDTV isn't here yet
A little Upgrade advise
