Record Plus | SatelliteGuys.US
Record Plus
TMaud
21
Can sombody explain to me the purpose of 'Record Plus'? I saw it in the Setup menu but I wasn't sure what it is for. Does it mean that if I am using the TV1 remote I can set up a DVR event to occur on TV2's tuner or Visa-Virsa?
In short, yes.
You chose the default to whichever you use less often (most people have TV2 set) and then even if you're on TV1 and set a timer, it'll go to TV2. Any conflicts or overlaps go to the other one.
Of course, that doesn't work if you want to record what you're watching at the moment on TV1.
New LNB for X22's?
dish locals & analog OTA
