Recording 1 Channel, Watching another!!?? | SatelliteGuys.US
analoguesque
8
Why does DirecTV DVR require 2 seperate signals to watch one channel while recording another?
Using a splitter does not work. Why? :what
Logically (in my mind anyway :eek: ), the signal is decoded by the DVR box, so why wouldn't a splitter work?
I would appreciate any feedback on this because I'm pretty bummed that i can't use an el-cheapo splitter to record one channel and watch another. :(
Ian
el cheapo splitter can't handle the switching of 13-18 volts that come down from the sky
Your channels are on Transponders... thus different channels, different transponders... which require different voltage... hope this helps!
anyone else?
I have heard the only way to do this is with a stacker/destacker.
not sure what a stacker is but the multi-switch is what they are now calling a voltage switch. this is whats required unless you have the newer phase3 dish with built in switch.
How does the multi-switch work? For example, how would I use it to split the signal into 2 so that my DVR can have 2 inputs?
BTW, DirecTV hinted that the solution was a multi-switch, although they weren't exactly forthcoming on the support :( . I was told to speak to the techie where I purchased the DVR from. Think the guy at Circuit City who sold it to me is going to be able to help? Mmmm, I'm not so sure about that. :rolleyes:
Much appreciate the help, thanks.
Ian
I'm telling ya the only solution you will have is either run the second line from your dish to your Dtivo or get a stacker/destacker setup.
A multiswitch will not work.
anyone else?
Enlighten us on how they manage to send 13-18 volts 22 thousand miles without a wire.
This must be a hell of a satellite.
The voltage is provided by the IRD, through your homes cabling to the LNB on the dish. That 13/18 voltage changes the direction of the circular polarity in the LNB to receive odd and even transponders.
The pricing is extremely prohibitive though. I may as well install another DirecTV DVR upstairs and it would be less than half the cost :no
Getting feeds from networks via DTV
Directv sends different hd reciever
