Recording from another source with a DVR | SatelliteGuys.US
RedSavina
710
Groton, CT
Is it possible to record a modulated signal from another source over the OTA RF input (for boxes equipped with one)? If so, I would expect to have to create manual timers. What about trick play features (i.e. buffering)?
Are there other ways to use the DVR capability to record programs from another box?
I know the Pansat 9200HD has both PVR and OTA capability; I believe there are others...
Thanks,
Red
not that I'm aware of.
Unless the receiver has both a PVR and a built in tuner, all the RF in and out does is a passthorugh.
The Pansat 9200 is not PVR capable yet but it does have a OTA tuner
Ice,
Thanks. Any idea when the 9200 will be able to take advantage of the eSata port for DVR?
Something just occurred to me. IIRC, the OTA tuner on the 9200 is ATSC-only. However, this post from you leads me to think otherwise. So I looked up some specs but they are not specific enough...
Is the OTA tuner NTSC (analog), ATSC (digital, 8VSB) or both?
Thanks!
EDIT: Above should read, "Is the OTA tuner input NTSC (analog), ATSC (digital, 8VSB) or both?"
The input on the 9200 is ATSC only. It will only pick up the digital channels. Here in Minneapolis we have 5 or 6 low powered translator stations (one is WUMN 13 Univision that is on G10)...the 9200 will not pick those up
Configuration Ideas for first FTA setup
Recommended Gear for FTA Newbie
