Recording locals in HD? | SatelliteGuys.US
CEV
SatelliteGuys Guru
142
15
I'm about to order my first HD tv. It will be a 50" Plasma. I currently have DTV but not the HD setup. I primarily watch primetime tv on my locals. I will want to be able to record these in HD. Will the HR-20 do this for me? I currently have a second dish for the locals that come from Sioux Falls, SD which is about 60 miles away. I'll be calling DTV soon to get an upgrade to HD with the dvr. Will there be any issues that anyone knows of?
Thanks,
CEV
Thanks,
CEV
Your hd locals will come from the 99 or 103 slot in mpeg4. Your HR20 will be able to record them just fine, when they are available, that is.
HD locals
Sioux Falls is not currently in HD from Directv, and Probably wont be for a long time as it is a very small market. Get the HR 20 and put up an off air antenna for locals. Give s your zip code and we can tell you which antenna is best.
..... Give s your zip code and we can tell you which antenna is best.
57006
Will I still be able to record the locals off the antenna? I am able to now in Standard Def, but would really like to in HD. Does DTV provide and install this OTA antena when installing the new 5-lnb dish?
Thanks,
CEV
The antenna you would need would likely NOT be provided by DirecTV. I would look into maybe a Channel Master CM4228 aimed at 162.5°
I see you have no FOX digital if this is up to date, and FOX is provided by a translator/repeater. K50DG from Brookings. Do you have 2 NBC channels?
I get my locals through DirectTV at extra $4.99 a month.
57006
Thanks,
CEV
Yes the HR20 will allow you to record shows from OTA. I think they sell an antenna which fits on the DISH. YOu need to be really close to the towers. I would goto radio shack and pickup an outdoor antenna. I live 80 miles from my local stations. I have my antenna mounted in my attic and get OTA just fine.
No Fox station listed at all, thats bizarre ...
Jimbo
In SD (analog) ONLY correct? I will need a quality antenna setup correctly to pull the digitals in your area and if I am correct, you can feed that OTA into the HR20 for recording.
Is this your scenario? What your are wanting to do?
He has FOX analog provided by a repeater tower basically right in his backyard; I don't think repeaters/translators provide any digital.
Oh, Ok,
I do not have to deal with repeaters so I have no idea if it's digital capable or not, glad I'm not in that situation.
Jimbo
Yes, that is what I am wanting to do. I want to be able to have the HR20 record my locals in HD.
Thanks,
CEV
NFL Week 1 ST schedule
RC64 remote
