Recording with 722K | SatelliteGuys.US
Recording with 722K
Chris36
448
4
Rhode Island
Just a quick question. Does anyone know why sometimes a program doesn't record the whole thing?? It's happen to me twice now it will just record the first 20 minutes or so and stop recording in the middle of it. It's not a space issue I know that.
I'd pull the plug on the power for 5 minutes and do a check switch. With any luck your problems will stop. Only other reason I've seen is if you have a power spike or interruption, but typically it would refire and record the remainder of the program.
If it does restart and the time between the first and the second parts is say 5 minute, then it likely rebooted on its own. It could be a bad OTA signal even when recording satellite or it might be just confused.
-Ken
Daily power down
How Come Dish won't carry PBS- HD?
