recordings starting 1-5 minutes late? | SatelliteGuys.US
detroit_fan
331
SE Michigan
ever since i received 0x5cd i have been having all kinds of problems, but the one that is really troubling me is that my recordings are starting 1 minute into the program. some shows even went 2-5 mins in before starting to record.
is this a known issue with this update?
what in the heck was D* doing pushing this update out with all these bugs?
it is happening to pretty much every recording on my HR22-100, my HR21-700 seems to be about 50% of the time. i've been with D* for over 10 years and I have had more problems since the 0x5cd update than the last 10 years combined.
Well i did the reset and my HR-22 is still starting 1 minute into most shows. I think I have found the cause- the channel is taking a minute to change. Even when nothing is recording and you try to change channels it doesn't do it right away, it takes a minute to complete the change.
Any ideas?
I have native turned on, and all resolutions selected, could that be causing the delay when switching channels causing the recordings to be 1 minute late? should I turn native off? if so, what resolutions do i leave checked?
PPV Commercials Cutting Into Programming
