Remote Code for a Olevia TV......21.0 IR/UHF | SatelliteGuys.US
ouch1234
88
31
Norman, Ok
Any help with some additional codes would be great? I even tried to scan for code..No luck... Called Dish too..No luck. I've had this TV working with a Dish Remote before, and have verified the remote is in working order with another TV.
?Thanks.
Olevia codes: 564, 578, 580, 910
I used to have an Olevia 537H, and I used this remote with it successfully. I don't remember which code I used though, and I dumped the tv in April finally after almost 7 years.
21.0 is a learning remote, could someone have taught the remote the codes for your TV?
Nope, I set it up myself. My wife can barely find any of the remotes, so I'm it. I know I did it via a code from the book, and did not use the learning function.
Don't any of those codes I gave above work for you? Which model Olevia do you have? Mine was the 537H, which was a 37" lcd.
Primestar the question was for the OP not you.
External hard drives
Best Education Channels for Kids
