Remote code needed | SatelliteGuys.US
Remote code needed
SAT COOL
42
York,PA
Hi I have a Dynex 19" Tv in my RV I am looking for a code for a dishnetwork remote it is a 3.2 IR NUMBER 137180 I DID THE CODE SEARCH WITH NO LUCK. If anyone can help please get back to me thanks.:)
You will probably need to get a new DISH remote. When manufactured the codes are put into the chip and can't be changed. If the TV is newer than the remote the onboard chip probably dosen't have the correct codes.
Look for a 20.0 remote. They have a lot more updated codes in them and you can program it to anything if you have the original equip remote
I would suggest looking for a manual for the remote you are considering, to see if it lists your model, before buying the remote.
My book essentials question
Antenna grounding
