Remote Codes for H10 (Mfr code 200) | SatelliteGuys.US
spectrumsp
40
Florida
We just purchased a Mitsubishi WD 52628 and a D* H10 (Mfg code 200) receiver. They work wonderful together...the picture jumps right out at you!
However, I am having a problem finding the proper code to use with the Mit remote to program it to work the H10. Mit tech has no idea.
Has anyone had any luck finding codes to program remotes to control the H10?
Thanx in advance...
mitsubishi remote probably wont work the H10
try these codes for the H10 remote for the TV 10093, 10150, 11250, 10178 first one works 95% of the time. even if the other remote did work, no remote controls all functions on other products.
good luck
BTW, i would have sprung for a pioneer elite
NFL sunday ticket cost
Aiming the dish for 119
