remote contro | SatelliteGuys.US
remote contro
ayalda
9
My remote controls are interfering with each other. Any solution for example I could change channels from one room to anther.
menu > 6 > 1 > 3 System Info Remote Address
If you want to change address remote and box
Remote
Press and Hold SAT Mode button till lights flash
Press 2 (Press 1 to 16 to pick remote channel)
Press #
Press record
If you want to change address remote only
Remote
Press (any number 1 to 16)
Press #
thanks,,,,,tried it did not work any other suggestion
What dish receiver and what is your set up. Make sure only one box is on or you program both.
Change the Address PVR 510
Because UHF signals travel long distances and go through walls, a
neighbor's remote could control your receiver by mistake. To handle this
problem, you can change the address on the remote and receiver as follows:
1. Make sure you turn on the TV and receiver.
2. Open the Important System Information menu by
pressing the receiver's front panel SYS INFO button.
3. The Important System Information menu shows a
Remote Address.
Write down this number:
4. Press and hold the SAT mode button about three seconds, until
all the mode buttons light up, and then let go of the SAT button.
5. Use the number buttons to enter any number from 1 to 16, but
not the one you wrote in step 3.
Write down the number you enter:
6. Press the POUND (#) button. If you entered the address correctly, the
SAT mode button flashes three times.
7. Press the RECORD button.
8. Make sure the Remote Address you see on the Important System
Information menu now is the same as the one you entered in step 5. If
the addresses are not the same, repeat step 7.
9. To check the address in the remote control, press and hold the SAT
mode button for three seconds. Then, let go of the SAT button, and
press the POUND (#) button twice. The SAT mode button flashes the
same number of times as the address you entered in step 5.
Press the SELECT button to close the Important System Information
menu.
http://www.dbsinstall.com/PDF/Manuals/Dish_Player_DVR_510_Chapter2_web.pdf
Best DISH for 129 in South Carolina?
Best Config
