Remote control code for Vizio | SatelliteGuys.US
abaway
29
South Florida
:rant:How many years has Vizio been making televisions now? Why doesn't Directv have Vizio listed in the remote control setup in the receivers? I've seen many brands that I've never heard of, yet no Vizio.
I have used my Directv remotes with Vizio TVs for nearly 5 years and both my HR21 and HR24 list Vizio (I recall that some earlier firmware versions had it as VINC). Try 11758, 10864, 10885, 11499 or 11756.
Thanks for the codes. I got my tv set up manually with the code search, but just wondering why they don't show it in the receiver menu.
What recvr are you using ?
I'm asking because the HR24 remote is set up different than any I have ever used before.
You tell it what TV and Model and it finds everything from there. :cool:
There is no list of TV's, you type it in like the Smart Search. :D
Vizio uses a very old codeset, every remote with tv list in the last 20 years has some kind of working code. Just use the Goldstar tv codes. As for the rc23 the codes are 10178 & 10056. only code 11758 will give access to the tv input command, that is only available in rc64 & rc65 remotes.
USB ports on HR24
hr20-700 tuner/transponder question
