Remote Control Question... | SatelliteGuys.US
leejohnson
Hello- I have a question someone may be able to help with...I hope!!!
We have a 622 Receiver and the remote control #2 has been 'lost'. I hate to spend $30- -$50 to replace it at the moment and was wondering if anyone knows if there is any way to control TV #2 without the remote.... (The lost remote is a 6.3 IR/UHF Pro, if that helps...) I may try to hold out a bit longer in hopes of finding it but it would be nice to be able to watch TV #2 in the meantime!! Any help and suggestions are so appreciated! Thanks so much!
You can lay out hundreds and get one of those fancy wonder remotes. Because the TV2 remote is UHF, you can't just buy a $10 will-fit unit.
eBay is full of Dish remote controls. The shipping may cost more than the remote.
OKC Locals In HD
Cable company trashes satellite coax
