Remote Control Settings | SatelliteGuys.US
rric31
3
Maine
Is there any way to change the settings on the Hopper remote control? I would like to change the fast forward button to 2x instead of the 4x that is the default. Other DVR's that I have had also have a feature that when I stop the 2x fast forward with the play button, it backs the video up about 5 seconds. Is there any way to make these adjustments on the Hopper remote??
rich in maine
Those are not remote settings. They would be device settings and they are not available options.
Use the skip forward/back button for skipping commercials, works much better than fast forward.
Also an option when you are fast forwarding and see the point you want just hit the skip back button instead of play.
Can you set parental controls on a folder in the DVR?
Hopper and Tailgater
