remote control | SatelliteGuys.US
remote control
Not open for further replies.
odrozd
3
ANY IDEAS ON HOW TO CONTROL A SATELLYTE BOX WHICH IS INSIDE A CLOSET.
tHANKS
You need an UHF remote...as opposed to the IR that you are now using. If there is not one available for your receiver, you can purchase a IR/UHF converter. You can probably find one at DishStore.net.
You can use the pyrmids that are sold at many stores such as radioshack, best buy, target, circuit city,. You cab get them between 30 and 50 bucks depending on which brand you choose.
Costco: ViewSonic 22" HD-Def Widescreen LCD for $299.99
Hawaii EQuake - ABC Stream
