remote delay coming on from standby | SatelliteGuys.US
  • Thread starter Thread starter asmodeus
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
asmodeus
Hi
I have a 722 and a Harmony 880. When the 722 comes on from standby, there is always a response lag with the remote. I have also tested with remote 1, and the same problem happens, so it's not the harmony. After coming on, it will accept every few keystrokes and then after about a minute or two it will respond to everything and run fine. Also, it only seems to happen after the 722 has been off for a long period of time, e.g. overnight, but not after an hour or so.
I only have a single set in the house, the DVR set to single set as well, and the remote is RF if that makes a difference.
Anyone else have this problem? solutions? bad box?
Can you recommend an OTA antenna? Say from Circuit City or Best Buy?
Turning on subtitles/cc with one button?
