P PaulieORF SatelliteGuys Pro Original poster May 19, 2005 173 0 Southington, CT Jun 17, 2006 #1 Nevermind, I fixed it. Last edited: Jun 17, 2006
VIPERS-PIT Pub Member Feb 11, 2006 2,099 0 Jun 17, 2006 #2 lol. any direct remote (save the TIVO) will run the H-20.
mcbeevee SatelliteGuys Pro Dec 28, 2004 223 0 Jun 19, 2006 #3 If the H10/H20 remote does break, you can get a new one from Value Electronics for $19.99. http://www.valueelectronics.com/accessories.htm#TOP
Smthkd SatelliteGuys Pro Sep 1, 2004 571 0 ATLANTA Jun 19, 2006 #4 Or you can just replace the batteries!
Jimbo SatelliteGuys Master Lifetime Supporter Cutting Edge Jul 14, 2005 70,055 8,415 NW Ohio - Buckeye Country Jun 19, 2006 #5 mcbeevee said: If the H10/H20 remote does break, you can get a new one from Value Electronics for $19.99. http://www.valueelectronics.com/accessories.htm#TOP Click to expand... Make sure you ask for the RF remote if that is the one you need. (RF24) D* has two different ones out, they look almost identical. Jimbo
