Remote for RCA DTC-210 | SatelliteGuys.US
mroodey
22
Will a RC16 remote work with a DTC-210 reciever? If it will how do you program it?
I'm not sure what that means. What code is the dtc-210 supposed to have? Do the remotes just work and not need programing?
No, it uses a code that isn't in the rc16. The directv device on the rc16 only accepts codes 00001-00004. Which are only for d10 and subsequent models.
The dtc-210 code in white remotes with Format key, like rc23, rc32, and rc64 is 00392.
