remote help | SatelliteGuys.US
remote help
dunncottage
7
nh
can an 8.0 uhf pro remote be programed to operate either a 721 or tv2 on a 622 ?
if so -how do you do it. i ve tried holding sat for 3 seconds till all the buttons light up and then plugging in address, pressing # twice and then record with no success.
any suggestions ?
Make sure you're on the system info screen, that's the only place pressing record will change the address.
The 8.0 remote should work for a 622. It is UHF-PRO not UHF so it will only work for the 721 if it also transmits IR. I don't think it does but I could be wrong about that.
Coax Grounding question -- Help!
Satellite Meter
