Remote help | SatelliteGuys.US
Remote help
DBENE
87
I was trying to program my Mitsubishi universal remote for the Voom STB but on the manufacturer's list Motorola is not listed. Does anyone know thier code or am I out of luck?
I would use the Voom remote but it has no PIP and also for some reason the input button doesn't work for my TV on the Voom remote.
TNT HD having problems with channel?
Good luck, Voomers! (If you don't reboot daily)
