Hello all. I posted here before some time ago but I couldn't figure out how to view my old post. I have a 3 part issue.
1. Our receivers do not update. I was told because we are in a remote location in Shemya, AK that they cannot lock onto the transponder to do the update? Not sure this sounds right. Are the updates used for more than just the program guide? Software updates? If so I'm wondering if I can download them on a laptop then upload them to the receivers.
2. Our signal is fuzzy/snowy by the time it makes it to the rooms. I know this is a vague issue but would it even be possible to get a clear signal? We have 45 Dish receivers that run by fiber to a fiber to copper converter in another building about a half mile away. They are then put onto a combiner along with local channels, server channels, and AFN channels. This is run through a splitter to go to the various floors of that building where it is amped and split at each floor. Another run off of the splitter gets converted back to fiber to go to the dormatories where it is converted back to copper, amped and split to go to the different floors. At the end locations some channels are clearer than others. This is old copper coax that has probably been in place 30-40 years and I'm wondering if after all of the splitting and amping and converting from fiber to copper to fiber if a clear signal is even possible. All channels have a little bit of fuzz/snow with the higher channels getting more diagonal lines. The channels start very clear at the pick off from the receivers.
3. We get the America top 200 or whatever it is called. We are supposed to get several channels that don't come in like HGTV, Fox news, Cnn, Cartoon Network. They all say "Channel signal loss" when we go to them. I was told that this may only be possible to get with a "spot beam". Our satellite is 129 Echostar west (on the Super Buddy, it says 129 Ceil-2)
** I have uploaded how the channels appear in the room. It is still very much watchable but people want it perfect. I'm not a satellite/Dish guy, the Comm department just absorbed this when they got dish receivers.
