Remote problem | SatelliteGuys.US
Remote problem
larryah
79
Bartlesville,OK
The remote for the SD receiver in the bedroom has gone belly up. It will not operate anything. Brand new batteries did not help. You can operate the receiver from the front panel, but remote is dead. Is there something I can do to fix this, or replacement the only option? Remote is only eight month old.
If you have another one, try it and see if it's really the remote or the ir receiver on the box.
Called D* last night and as I suspected the remote was bad. I do have the protection plan and they are sending me a new one. I do appreciate the info. I did not know the remotes would work of any receiver! You learn something new every day!!
Thanks!
Approved MRV Method
Upgrading from a "grandfathered" package
