remote won't work | SatelliteGuys.US
remote won't work
lacubs
1,596
42
Erie, Pa
i just got home and my remote won't with my HR34 any idea ? i mean the some buttons will work but not the main ones , i tried two already
Try to reset the remote. Press and hold MUTE + SELECT until the light flashes twice. Enter 981 light will flash four times.
Doing this will reset all codes, tv, av1, av2. You will have to enter your code(s) for your tv and any av gear you had programmed after you have reset the remote.
Comparing Hopper and Direct TV systems
slimeline 3
