Remote | SatelliteGuys.US
Remote
ejb1980
3,406
586
Vermont
I accidentally posted this in the wrong area originally. My bad...
A while back I posted about new remotes and getting the tv code in. I was given a code for my LG TV and it turns it off and on but that's it. The left and right arrows work on select menus on the tv, but not many. Previously, I was able to change inputs with and use the Directv remote for everything on the tv, including menu, settings, etc. What code will bring all that back? The LG smart remote is the dumbest remote I have ever seen and would like to use my Directv remote as I used to do.
Remote is rc65rx. Receiver is HR44. I have the HR44 remote (the second dumbest remote there is) in the bedroom in rf mode. It's a pain, but inputs on my Samsung TV in the bedroom can be changed with the HR44 remote.
Slide the bar to tv.. mute + select. Blinks twice.. 10178... blinks twice.. mute + select ... 960.. count how many blinks. If two your done.. if four.. mute + select .. blinks twice.. 960.. blinks twice.. now your done. Slide bar back to dtv mode.
That is the code I have now and it behaves as described!
AT&T Weighs In On Net Neutrality
Genie upgrade to existing system
