remotes quit working | SatelliteGuys.US
donwylie
16
dallas texas
I have 2 identical H20-600 receivers and the remotes on both quit working today at the same time. They still both will control their TV functions sound power etc, but nothing on the receiver. I called D* tech support and they are sending me 2 new remotes, but I can't believe that both would stop working at the same time.
I was watching TV in the den and had been changing channels previously and then nothing.
Has anyone else experienced this problem ?
thanks
Don
I changed them back to IR and they both started working. Must be a problem with the RF.
Thanks for the hint on what to look for..45 minutes with D* tv support didn't fix it, so you should get a job working for them hehe..
Don
Don
Don,
Brewer will probably be insulted by your offer to work for thier CSR 's , I know I would.
Anyway, does your H20-600 have the internal or external antenna for the RF ?
If it's the external, try moving it some, possibly got blocked by another item in the way.
Jimbo
Now that the infrared is working you should be able to switch it back to RF. Something may have just got reset. I had similar issues with phone over power line devices.
Next CE is Friday
DIRECTV Adds New HD Channels for Fall
