Does anyone know the Satellite and Transponder(s) that local channels for Reno, NV are on? I get Pixelation occasionally. I want to tune them better.
Thank you, 99s transponder 1 is the worst level (47) I have. I guess some fine tuning is required.to Satelliteguys Mathnado!
Reno hd locals are on 99s transponder 1. The sd versions are on 119 transponder 29.
Good luck!
But Sacramento and Reno, are they in the same Spot Beam ?FYI ... I’m in Sacramento and my signal level on 99s Transponder 1 is 98, so it would surely seem that your dish needs some alignment help.
Sent from my iPad using SatelliteGuys mobile app
That works perfectly fine if both cities are in the same spot beam.I don’t know about that, but figured it was likely that whatever was hitting my dish on 99s would be the same as what’s hitting Reno, given the close proximity. Could be wrong though, so I’d defer to others who may know better.
You are only 125 or so miles from Reno, so you are definitely seeing the same beam that is directed at Reno. Other beams in the general vicinity may show a lower number if the area it's pointed to is farther away.Thanks for all the info. If I’m reading this correctly are you saying that when looking at my receiver’s signal level display for 99s/T1, it will change based on the locals that it’s authorized for? Or are you saying that I may simply be looking at a different spot beam?
As Chip mentioned ...Thanks for all the info. If I’m reading this correctly are you saying that when looking at my receiver’s signal level display for 99s/T1, it will change based on the locals that it’s authorized for? Or are you saying that I may simply be looking at a different spot beam?
Seeing your in the same area, you ARE seeing the same one ...
However, like I said, that Sat and trn is in various locations to give other stations in other areas of the country.
It definitely is helpful. Thanks!Thanks, that’s what I thought. My original reply was hopefully helpful to the OP — just wanted to give him some idea of an expected signal level. Figured since I was so close, the info would be valid. Sounds like it is.
Limited time offer
