SmityWhity said:I don't have a Dish 1000, but I'm thinking that the perimeter of the arm on the SD 121 is larger than the arm on the Dish 1000 - but more importantly it is bigger than the opening on the W-Bracket from the 1000.
If the same size - good, but in either case, when you try it, you may have to move the Dish 1000 assembly inward or outward to get the correct focal point(s). Plus, your skew, elevation, and azimuth will change.
If it wasn't for my family liking TV, I would pick up a W-Bracket and try it myself since I would rather know what makes it tick than watch TV.
I seen one post where someone took the Dish 1000+ LNBF assembly and modified it to work on a SuperDish for 119/110/118.7/129, but that is the Plus version and not the standard. Myself - I just duct taped a Dual LNBF to the side of the shroud so that I can pick up 110/119/121/129, and will make a permanent mount for it if Dish doesn't come out with the repoint kit.
Please let us know your results.
SmityWhity said:SuperDish 121 w/DP Dual LNBF Duct Taped to Side of Shroud for Sat at 129
ViP 622 Receiver
HD-Silver, with Denver Locals, & Korean Variety Package
Denver, CO; 7/18/06 5:15 - 6:00 PM
Heavy Clouds with Thunder from the South
No Rain yet, but Heavy between Here & Colorado Springs.
HD Programming
CHNR SAT/TP LO/HI CHANNEL ID
6330 129/02 67/68 KMGH Denver Local HD
6331 129/02 67/68 KCNC Denver Local HD
6332 129/02 67/68 KUSA Denver Local HD
6333 129/02 69/70 KDVR Denver Local HD
9420 110/13 74/75 TNTHD
9421 110/17 77/78 DSCHD
9422 110/07 80/81 HDNET
9423 110/07 80/81 HDNMV
9424 110/17 77/78 ESPHD
9425 129/19 61/62 ES2HD
9426 129/10 66/67 NFLHD
9427 129/19 60/61 UNIHD
9461 129/22 63/65 HGHD
9465 110/13 74/75 HDEV1
9466 110/13 74/75 NBAHD
9467 110/13 74/75 HDPPV
9470 129/30 67/68 RAVE
9471 129/23 62/63 EQUTR
9472 129/03 62/62 GLLRY
9473 129/11 60/60 TRESR
9474 129/23 60/61 ANIMA
9475 129/11 57/57 WORLD
9476 129/03 58/59 RUSH
9477 129/11 57/57 WSPOR
9478 129/31 66/67 ULTRA
9479 129/30 67/69 KNGFU
9480 129/03 61/62 FILMF
9481 129/23 59/60 MNSTR
9482 129/30 66/67 HDNWS
9485 129/31 68/69 GAMEP
9486 129/31 69/70 FAMLY
Other Programming
9602 119/11 75/76 BTV
9630 121/25 77/78 BTV
9635 121/13 76/77 BTV
9850 121/15 59/60 KBS
9900 110/10 67/68 D500 You have a DISH 500
9901 129/17 55/57 D1000 You Have a DISH 1000 System
-101 119/17 75/76 DNFYI
-102 119/16 77/78 TVGC
-112 119/06 77/78 HGTV
-118 119/10 76/77 A&E
-217 110/14 84/85 DRIVE
-280 110/02 85/86 FREE
-284 110/03 64/66 LIME
-404 110/15 78/78 HRTV
-661 121/02 75/76 WOWTV
-668 121/16 61/62 JSTV
-704 121/15 59/60 KBS
-705 121/05 74/75 ARANG
-900 121/25 77/78 D121 You have a SuperDISH system…
8200 110/22 89/90 KMGH Denver Local Channel 7
8206 110/01 124/5 KRMA Denver Local Channel 6
8215 110/01 124/5 KZCO Denver Local Channel 27 (CO Springs)
Limited time offer
