Replace HDrive | SatelliteGuys.US
Replace HDrive
This1
261
Florida
Looking to upgrade my hard drive on my DVR to 1.5 TB
Is there anything special about there hard drive or any sata hard drive will work
Also will this void any warranties since I have protection plan on own receivers.
Why don't you just use an esata drive and not worry about voiding your warranty.
If you are going to replace the drive I would do it with a Western Digital AV SATA drive. Replacing the drive will void your warranty of the DVR. You might be able to keep the old drive and replace it back into the device if you need to have a replacement. The only problem would be if your receiver has the seal to show if the box has been opened.
Any future HD coming?
PROTECTION PLAN
