replace joey with hopper | SatelliteGuys.US
Not directly. First you need another host port on your node. So if you currently have one hopper you need to up your solo node to duo. For that you will need 3rd line from lnbf. If you have 2 hoppers already and planning to add another there must be switches and another node involved, for that you can find diagrams in other posts. Lastly you have to make sure that cable that goes to joey you want to replace is rated 3ghz and is not splitted on the way.
Soap Channel R.I.P 1/1/14
Hopper - Locks up after 2 hours and reboots. What to do?
