Dish network does not have a replacement front panel cover available for purchase. Is there anywhere online or I can buy one for my receiver. I also need box...
Where else EBAY I have seen parts offered but you can also find auctions for as is or parts usually leased receivers that can't be sold for reuse.Dish network does not have a replacement front panel cover available for purchase. Is there anywhere online or I can buy one for my receiver. I also need box...
I would suggest a simple search for a "DISH 722K" that should give the broadest search but you will need to look at a lot of crap.I couldn't find it on eBay however, I may have not used the correct search terms. If I sell it I want to do so in original condition. Also, having an original box with the foam would help shipping it.
That sounds more like Backpage than Ebay......I may have what you are looking for.
Limited time offer
