Replacement LNBs for Super Dish | SatelliteGuys.US
tempVAdish
709
Temperanceville, VA
Any still available, or something to replace them with? I know we don't need the 105 feed anymore, anything that would let me still use it for 110 / 119????
I ask because the LNB drift now for 119 is -10dB, still holding -8dB on 110...
The 110 LNBF on a 105 superdish is a just dishpro LNBF that is out of its plastic shell,
The superdish 105 was aimed at 105 and the others are off to the side.
If you want to do a reaim with the super dish you can install a dish 500+ LNBF (110/118/119) or the dish 1000+ setup with the bracket for 129 both are centered om 118.7. You would just have to drill new holes in the LNBF support arm to mount.
If you dont need 118 or 129 you could also get a dish 500 yoke and LNBF for 110 and 119. that would require a reaim on 114.5.
But I see from your signature that you require 129 so you could also probably get a 1000.2 LNBF and yoke and reaim at 119.
So, you're saying I can use the super dish reflector for 110, 119, & 129??? Would the signal strength be as good as if I just used it for 110 & 119???
they have a Y-bracket out that makes it possible. I believe that bracket and the superdish make it a 1000.5, been some discussion about it here just try to search for it here:)
Yellow screen
Does anyone have a "black flash" problem?
