Replacement Receiver Missing Channels | SatelliteGuys.US
Briant73
SatelliteGuys Guru
148
5
Pennsylvania
Just got a replacement Dish 222, installed it and it's up and running but noticed some channels are missing. The guide is not even showing them but my 722 is receiving them fine and check switch looks normal (110,119,129) on the replacement 222. What if anything can I check before calling dish?
Try re running a check switch and verify signal, then back out and let it redownload the guide and see if that helps.
what channels? you dont have the guide set to all hd do you?
Even with All Channels for the guide display, channels are missing from showing up in the guide which I find odd since I thought they would show just not show as subscribed. I do see channels in the guide on my 722 and they are watchable. Was late last night so I didn't write them down and right now not at home. I am going to try these steps later 1) unplug power 2) plug back in 3) check switch 4) if needed call dish for a rehit.
Just PM Matt, like he asked, and he will send a hit to the receiver, that will probably fix the issue.... No need to call Dish when we have the best Dish folks right here on this website....
Is there a warranty on the Sling adapter??
Dish makes bid for clearwire
