Replay and VOOM problem help | SatelliteGuys.US
DMARR35
7
:( I have read threads on programing the Replay to get channel info from VOOM. I 'm average at the computer and i'm geeting confused with the process. Can anyone please simplify the process needed as far as the program I need,what has to be done step by step as simple as possible for a simple guy like me! Thank YOU for your time!!!!!!
I'd check the AVS forums, they can walk you through it. From what I understand you need to use WIRNS and load the channels into the Replay from there Replay will pick up the channels when it downloads the guide.
There is also a good link here:
http://www.satelliteguys.us/showthread.php?t=11828
I had some problem initially because I was gatewaying my replay into my network by directly connecting to a computer that had a wireless connection to my router. After getting one of those gaming adapters for the reply and following the Wirns directions. All is well.
Good luck!
Do you need a subscription to RePLAY to make a 5000 model word with VOOM as far as programing with wirns?
HDDVR add-ons - will they work with Voom?
2 More Weeks!!
