Request: need info of Satellite 118 | SatelliteGuys.US
ravurus
2
Hello all,
I am trying to move to a new apartment and want to find if i can view Internation channels on satellite 118 from my house.
Is there a way i can find the angle needed for this satellite to check with my compass. I know we need to have line of sight in south-west but need more details to check.
Any help will be greatly appreciated.
virtually the same pointing as 119. If you have a dish receiver already, go to dish pointing, plug in your zipcode and select dish 300 and satellite 119. It will give you all the required angles.
Need Info on Satellite 118
Pepper,
I did try in System Setup > installation > Point Dish option giving my zip code (32771) but i did not give me any angles. Sm i looking at the wrong option?
Pepper,
If you are using a D500+ or D1000+ per thelist it shows
118.7°W Anik F3 Ku
elevation 37.2°
azimuth 243.2°
dish skew 47.9°...skew that amount off of 90
Help with Dish local video on SD sets
So...what are the odds of Voom making a triumphant return?
