Resetting HR20 | SatelliteGuys.US
Resetting HR20
igzo99
109
Guys...will resetting the HR20 to illiminate bugs, erase recorded shows?
No, will reset the guide data for a while, but it will come back entirely over 24 hours. The first few hours in a matter of minutes. No recorded shows or scheduled recordings will be lost.
You should be aware, however, that the HR20 takes a lot longer to come back from a reset than the R15 or D11.
It started to worry me the only time I've reset mine.
Thanks for the tips. Looks like I'll reset it at a time I'm not going to need it right away...thanks!
It's really not that bad, it takes about 5 minutes ...
But it is longer than the other receivers.
Jimbo
Is it possible to get a new dish? (Directv)
AT9 and 6802
