resolution setting on H-10 | SatelliteGuys.US
tim1970
16
When I set up my box, I set the resolution on 1080i/480ip. I could not use native mode, since my tv does not support 720. Now when I switch between hd and non hd channels, I have to use the format button on my remote to choose the correct resolution. Is there a way to for the box to automatically choose either 1080 or 480 depending on the channel?
THanks
Tim
THanks
Tim
Just let the STB upconvert everything to 1080i. Unless I'm missing something, there should be no reason to change from 1080i. The STB can be set to automatically put pillar columns on the 4:3 image or to use one of the stretch modes. This is how I use my RCA DTC210. Usually the STB does a better job of upscaling.
I'm also confused that you say your TV doesn't support 720p. What TV are you using? Most non-720p TVs will accept the 720p signal and automatically upconvert to 1080i. Have you actually tried to use the Native setting? What happens when you tune to 720p?
My TV is a Mitsubishi 55" Rear Projection CRT. Sorry, but I can't remember the exact model number. When a 720 signal is sent to it, the screen starts flashing, and displaying all kinds of weird images. Similar to using a refresh-rate on a computer monitor that is not supported.
Must be an older model. Like I said originally, I would just let the H-10 upconvert everything to 1080i and leave it.
Commercial installations
West Feeds of Network in O&O Market gone?
