results of blind scan on satmex6 and satmex5 c-band | SatelliteGuys.US
chaskuchar
807
14
saint charles, missouri
Please share the SatMex Blind scan testing results of the logged transponder/channel list along with your location, dish size, LNB(f) brand/model/configuration. I will will be happy to rescan SatMex nexxt week and post the Blind Scan results of the microHD for your comparison.
location, 41.69467n, 97.48836w. solomend/openbox s9 with firmware hds2-11-03-21:01a2m
7.5 solid dish, homebuilt legs with dmx-741 lnb, gbox 3000, and new actuator.
in order to do a blind scan, erased all existing 21 channels on satmex6 and deleted all transponders except for existing imagen 3875/h/4166. then blind scanned satmex6 at 13feb2012 at 0100Z.
For satmex6 results: as listed on channel screen for the firmware.
1. 3875/H/4166 IMAGEN
2. 3864/H/2412 Service 2
3. 3818/H/3253 TRV HGO
4. 3778/H/6528 Ch-2
5. " Ch-3
6. " Ch-1
7. 3771/H/2874 CANAL TRECE
8. 3943/V/3700 PARHTV
9. " SNT
10. 3852/V/5712 CABLECOM
11. 3844/V/7015 Ch-1
12. " Ch-2
13. 3782/v/2399 Digital 1
14. 3762/V/3253 RED NACIONAL MEG
15. 3758/V/2891 Ch-1
Those are the channels for satmex6. satmex 5 has 47 channels so i will post them in the next post. charlie
channels on satmex5: 13feb2012 at 0055Z.
1. 3822/H/1808 PROMOVISION (existing channel on existing transponder) all other transponders were deleted before scan.
2. 4082/H/3161 GUATEVISION
3. 4047/H/3328 First_Service
4. 3083/H/3999 Cana_Judicial
5. 4030/V/15198 TELEMICRO
6. 4030/V/15198 TELEMICRO INT
7. 4030/V/15198 DIGITAL 15
8. 4008/V/6378 Teleantilias
9. 4008/V/6378 Coral 39
10. 4008/V/6378 Telesistena 11
11. 3994/V/15278 CH9 COLORVISION
12. 3994/V/15278 CH19 CINEVISION
13. 3994/V/15278 CH25 TELEMIDIOS
14. 3994/V/15278 CH33 SUPERCANAL
15. 3994/V/15278 CH33 SPORTVISION
16. 3994/V/15278 CH41 TELEVIDA
17. 3994/V/15278 FUNGLODE TV
18. 3994/V/15278 CH49 TV ARCOIRIS
19. 3994/V/15278 CH47 AME TV47
20. 3994/V/15278 Vinculo Perfecto
21. 3994/V/15278 TCD internacional
22. 3994/V/15278 Tele Canal int.
23. 3994/V/15278 CH59 MANGO TV
24. 3994/V/15278 CH23 TELEFUTURO
25. 3994/V/15278 test digital 1
26. 3994/V/15278 test digital 2
27. 3994/V/15278 test digital 3
28. 3994/V/15278 Radio Digital 4
29. 3982/V/3098 Ch-1
30. 3966/V/3253 TRC
31. 3742/V/2665 Ch-2
32. 3718/V/26999 CANAL 11
33. 3718/V/26999 CANAL 12
34. 3718/V/26999 CANAL 13
35. 3718/V/26999 CANAL 14
36. 3718/V/26999 CANAL 15
37. 3718/V/26999 CANAL 16
38. 3718/V/26999 CANAL 17
39. 3718/V/26999 CANAL 18
40. 3718/V/26999 CANAL 21
41. 3718/V/26999 CANAL 22
42. 3718/V/26999 CANAL 23
43. 3718/V/26999 CANAL 24
44. 3718/V/26999 CANAL 25
45. 3718/V/26999 CANAL 26
46. 3718/V/26999 CANAL 27
47. 3718/V/26999 CANAL 28
those are the channels i blind scanned on satmex5. all of them were live. just blindscanned fta. did not scan for pay channels. charlie
44. 3718/V/26999 CANAL 23
hmmm. i don't know how that line i had after i signed off got in there but it is not valid. i did have about 54 channels on satmex5 before i deleted them and the transponders before the blind scan. charlie
wow, your counts are off. There are 48 signals (single locks that are DVB-S or DVB-S2) that form 97 channels. You only show like 45 channels and probably 11 signals if I counted right.
Regular blind scan - satmex6 - FTA channels only
S9, FW ver. C2HS2-11-12-13:0481CMT
10Ft USS Steel mesh BUD, DMS421 LNBF on Port 1 of DISEQC
Erased all existing TP's (and channels) before scan, also power cycled to standby.
Loc. 48N 97W - start 0201Z finish 0207Z
Got all you have, plus:
between your #7 & #8
3764 H 2932 - RCG SALTILLO
4080 V 2918 - GLOBOV INTERNACIO
4075 V 3780 - TVT
between your #12 and #13
3834 V 1808 Mayavision
after your # 15
3756 V 2499 Service 1
3752 V 2891 TELEMAR
3736 V 3253 Teleforula_Netwo
Total of 22 FTA channels, 22 active TP's
thanks air. will add those transponders and scan see it i can see them. my bil has a ten foot channel master laying face down on his farm. that is my next project. maybe. charlie
fat air,
scanned satmex6 again and added 4 channels. i got mayavision and teleforula and added two new ones.
3824/v/4198 first_service
3775/v/2082 Ch-3. that one had a low signal level and had @superchannel 22 on the lower right of the screen. pretty gal is talking about cooking something. haven't figured it out yet.
with the other you had, i added the transponders and scanned them in right away. curious though, all these are Vertical. it might be that i need to set my lnb differently? anxious to get the microhd and see what the blind scan brings in. i have 26 tp's now and 24 channels on satmex6. charlie
skysurfer, i added all the tp's from the 'list'. before i did that i scanned 46 channels. after i added the tp's, i now scan 23 channels. hmmmm. that was with a blind scan. then i went to the preset scan. i get 39 channels. since i kept the channels i had with the first blind scan i have a total of 59 channels now. i do see there are some duplicates like SOY GUERRERO. charlie
skysurfer, i'm up to 67 channels now on satmex5. added tps, removed tp's, and edited the firmware to get the tp's in order for vertical and horizontal. but one problem. i scanned once with no tp's and i got a catholic religious indication of something about mary. should have written it down because after editing and changing i can't find in now again and it's not in sathints or the list. charlie
02 13 2012
8pm PST
Medium Cloud Cover
52 degree F
Receiver:GEOSATpro microHD
Dish: Sami 7.5 Mesh
LNBF: GEOSATpro C2
Coax: 100' RG6 Quad Shield
Satellite: SatMex 5
Logged:
Transponders: 36 (DVBS / S2)
Services: 89
TV: 88 (7 encrypted)
Radio: 1
02 15 2012
11:30 AM ET
Sky clear
51 degree F
Receiver: Prof 7301 PCI w/Easy Blindscan Pro software
4 Mhz Step
Dish: Channel Master 10ft SMC
LNB: California Amplifier Extended Professional II (pair)
Feed: Chaparral C band Orthomode
Coax: 260' RG11
Satellite: SatMex 5
Logged:
Transponders: 40 (DVBS / S2)
Services: 85
Total Services Entries: 124
TV: 84 (10 encrypted)
Radio: 1
after adjusting my 7.5' and inputting any transponder from sathint that showed signal that i didn't have before i scanned again. now i have 73 fta channels. this was a good learning experience in how blind scans don't get all the tp's. one of the tp's i put in from sathint had a low sq but scanned in 12 tv channels and they were holding ok while viewing. sq was varying between 10 and 30 so the blind scan probably didn't see it. l am waiting patiently for the new micro hd to hook up. one thing i thought about is using my 6' and dsr200c to see how many channels are there on satmex5. i can get the blind scan with it to be 2k apart. might be a good project for this afternoon. my 6 gallons of beer is not settled enough to bottle so i have free time... charlie
Chaskuchar, you may want to add to Satmex 6 @113 W all the Azteca Channels avilable at:
3900H 30,000. I am watching them with an Openbox S9 and an Ariza 1.2 mt dish with a 621 LNBF ( the 22KHz) version. Even though their ID show up as scrambled ($) they are open.
Dear Gents,
For years now, I have been trying to see "Inter Russia" on SatMex 5 at 4123 H 1790 2 / 3. Lyngsat has been showing this channel, and some other services have been showing it too. Others have not been able to see it, evidently, because they do not show it. Maybe the broadcaster has changed its "footprint." I used to be able to see it with my ten-foot mesh antenna, my DSR-920, and my Pansat 9200HD.
Has anyone been able to see it, perhaps along our southern border?
Thanks.
Gordon
Family Friendly Entertainment
I need a Firmware or third party software for my ADTH 8600ir receiver.
