Retro Tv | SatelliteGuys.US
Retro Tv
wzrd10
15
Holland Landing, Ontario
I am using a Coolsat 5000 and I am on 97W. This receiver does not receive the video transmission for retro tv. Will a Dreamlink T4 decode this channel?
I would strongly recommend purchasing another brand STB if you are also interested in other FTA channels. The Dreamlink T4 receiver is primarily sold for theft of service using key sharing It is not well supported for true FTA channels and is limited to only standard defintion MPEG4. If you already own the T4, then you will be able to blind scan the Luken channels on 97w. Otherwise, poor STB choice for a satellite hobbyist.
Reactions: Mr Tony
Yep, you don't want that one. :(
Ok thanks very much for the information. I only want the receiver for ku band signals on 97W. The coolsat does pretty good but I would like to get the Luken channels. Can you recommend some receivers for me that won't break the bank. I was on 83W but moved to 97W. I find this a fun hobbie. Thanks
Big Outernet Announcement Coming
Can LittleBits Save RadioShack?
