Reusing old hard drive from HR22. | SatelliteGuys.US
coinmaster32
916
14
USA
Okay so my neighbor switched to cable and gave me his old HR-22.
Inside I found a hard drive, with sata power and data cables.
I plugged it into my PC, but it won't spin. Is there some kind of proprietary system that won't allow you to use D* HDs in a PC?
Have you thought about the bill your neighbor may get when they find that the recvr isn't returned in time ?
Now that you broke the seal, they will know IF it does get returned.
The majority, 99% are LEASED and need to be returned to D* when turned off.
All D* recvrs work with sata / esata hard drives, that said, I don't know why it won't fire up power wise .
Yes it was owned.
I've been reading that the DVR uses some kind of "power on standby" and the drive won't spin in a PC.
Yes it was owned.
They must have changed that after the HR20 then. I own my HR20, but not my HR21. I opened up the HR20 and replaced the internal drive with a 2TB drive and pulled out the internal 320GB Seagate drive. It worked just fine in my PC after a format.
Unless he got it from a current/previous employee the odds of it owned are highly unlikely but not out of question.
Questions about apartment installation
Using a DECA with HR34 Genie Client (C31)
