RFD HD on C Band | SatelliteGuys.US
RFD HD on C Band
vc2
195
9
RFD TV lists the following info on their web site for RFD-HD cable affiliates, but they fail to mention which satellite they are using.
I couldn't find anything on Lyngsat. Does anybody here know which satellite they are referencing?
RFD HD Technical Specs
Transponder: C-band 19
DL Frequency: 4068 MHz
L-Band Frequency: 1082 MHz
Modulation: DVB-S, QPSK
Sym Rate: 8.680851 Msps
FEC: 3/4
Data Rate: 12.0000 Mbps
Format: MPEG 2
HD Format: 1080i
CA: Open
Net ID: Default
Channel: Default
Suggested Receivers:
Motorola DSR 4402x (must be in DVB mode)
Motorola DSR 4410 (must be in DVB mode)
Receivers that will also work:
SA D9850 (you won't see a picture until it passes through modulator)
Any Tandberg
Any receiver with an ASI output
Nice searchable list!
Thanks for pointing it out.
no problem
One of my favorite channels and when I used the 4 footer for C-Band I could pick up RFD TV (real low signal but stable) :)
After the bad weather
HITS programming...
