RG6 & Ground | SatelliteGuys.US
RG6 & Ground
jrv331
109
6
NE Ohio
I saw some RG6 that has the small ground wire attached to it. Im gonna try to do my OTA antenna this weekend. I will be using a grounding block for my cable wire and grounding it to and new grounding rod and to my main ground(using #6 copper) as well as my OTA mast, do I also need that type of RG6 or will "normal" do.
Thanks to all of you for the help
John
I would use it if you have it. Do it right first time and it should last for years! Good luck up there : )
